kingkevbo
Jan 31, 2023Aspirant
DHCP issues on RBR350
Dear community. I purchased an RBR350, with 2 satellites, and I have had issues with it ever since the start. I'm currently running the latest FW. I have one satellite wired and one Wi-Fi. Th...
Jan 31, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
kingkevbo
Thank you for your reply. I will answer your questions
As mentioned, the latest - V4.4.1.29_3.10.80
It is an o2 own branded 5G router, made by ZTE. It has built in Wi-Fi which is switched off, and DHCP switched off. It is connected to the WAN port and in a different subnet. Issues I have had in the past were the same with the modem connected or disconnected.
around 2000
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS
its greater than 30 feet in a diagonal straight line to both. across floors and even in a different building in the case of the wired one.
I have been on auto for 2.4 GHz, setting of 5GHz channel is greyed out, assume because I'm in Europe. Its set to 108(DFS) and I cannot change it. I have changed 2.4 GHz to chan 6 as per your recommendation.
1 or 2, very low power in my house, around -90dBm
Done, but if there are settings that cannot be used then this is a bug.
Yes, multiple times
I think this is unnecessary, given the circumstances of my issue. Things have been working for weeks after my last changes to the Tasmota devices to static IP. Given a reboot solely of the RBR350 fixed a stable problem then I don't think my issue is related to power up sequence. Also, I don't expect a high quality router, the cost of the Orbi to be sensitive to this. If I have a power cut or breaker trip, I am not going to religiously follow a strict power up sequence every time. If the Orbi is sensitive to this I might as well throw it in the trash.
Yes, multiple times
Its set to 192.168.200.2 to 192.168.200.199. My static IPs are set to 200+. I don't want to change this unless absolutely necessary. Again, if settings here are not settable to what the user wants, this is a SW bug and needs to be fixed.
I factory reset the router multiple times during my investigations. Problems arising weeks after initial setup I don't believe are related to power up sequences prior to it.
- FURRYe38Jan 31, 2023Guru - Experienced User
"What is the size of your home? Sq Ft?
around 2000"
For this size of home, only one RBS is needed. I'd turn OFF one RBS. you maybe running into devices ping ponging around trying to lock on to the best signal and can't figure this out. There maybe too much wifi signal overlap between the RBR and RBS in such a small size home.
A factory reset and set from scratch would be needed as a last resort check.
OK on the DCHP range. That's fine as well.
