gumpgump
Mar 17, 2021Guide
DHCP reservations and rebooting: WHY?
There's a threat from 2020 that I can't reply to about this. I find it annoying that in the year 2021 we have to reboot routers for a simple DHCP reservation change. Perhaps it's with IPtables c...
gumpgump
Mar 17, 2021Guide
Sorry, I am using the Orbi WIFI6 RBR850.
Firmware Version
V3.2.16.22_1.4.9
Mar 17, 2021Guru - Experienced User
What 2020 threat are you referring to?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
There is v12 available for manual download and manual installation:
- gumpgumpMar 17, 2021Guide
This is referring only to the internal LAN DHCP service.
When you create a simple DHCP reservation for a device, the firmware must reboot. This doesn't make any sense to me -- hence my question, wanting to at least understand why this is the case.
- FURRYe38Mar 17, 2021Guru - Experienced User
I think NG reboots to refresh the DHCP table and connections.
Is there a mailing list for new firmware announcements?
Some get emails some do not.
I think if your registered with there site and on there portal you should get an email.
They dont set out often...I tend too an eye on NG download page for updates
