Dominator1
Feb 03, 2024Tutor
Different IP addresses modem vs router
For some reason, my modem and router have different IP addresses, 192.168.0.1 and 192.168.1.1, respectively. I have a printer connected by ethernet that connects to the modem. my 2 computers and ot...
- Feb 06, 2024
That diagram is fantastic!
Dominator1 wrote:
I also realize that i might need to relocate the orbi router to the basement next to the IPS modem and connect directly from that to the various satellites?
Yes, move the basement satellite upstairs, connect the router directly to the ISP device, and then everything in the house connects to the router LAN ports. If there are not enough open ports, an inexpensive gigabit Ethernet switch in the basement will provide more connections.
Feb 07, 2024Guru - Experienced User
FYI, if you need the RBS to be ethernet connected, the need to be connected behind the RBR or if a LAN switch in in the mix, RBR>LAN Switch<RBS:
