Dominator1
Feb 03, 2024Tutor
Different IP addresses modem vs router
For some reason, my modem and router have different IP addresses, 192.168.0.1 and 192.168.1.1, respectively. I have a printer connected by ethernet that connects to the modem. my 2 computers and ot...
- Feb 07, 2024
That diagram is fantastic!
Dominator1 wrote:
I also realize that i might need to relocate the orbi router to the basement next to the IPS modem and connect directly from that to the various satellites?
Yes, move the basement satellite upstairs, connect the router directly to the ISP device, and then everything in the house connects to the router LAN ports. If there are not enough open ports, an inexpensive gigabit Ethernet switch in the basement will provide more connections.
Dominator1
Feb 13, 2024Tutor
thanks all. i moved the netgear orbi router in between the IPC modem and the splitter switch so that all wifi and ethernet in the house comes from the netgear orbi which is internet-supplied by the cablecom modem. works great so far and makes a lot of sense. thanks for everyone's help!
Feb 13, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
