gryphyn
Jun 16, 2023Aspirant
Disable 2G On RBR750
Is there a way to disable 2G on the RBR750? My devices are only connecting to on 2G for the router, but they connect 5G to the satellite. I want to disable 2G to see if devices connected to the route...
gryphyn
Jun 17, 2023Aspirant
Thanks for the reply!
I ended up downloading a WiFi analyzer, and it looks like the router isn't putting out a 5G signal at all. The satellite is, but once I unplug the satellite, there's no more 5G signal.
I'll look into the 5G thing further, but thanks again for the reply.
