mishikal
Aug 18, 2021Tutor
Disable netgear apparmor popup
Every time I log into my router, I get an annoying popup trying to get me to buy Netgear's apparmor. Is there some way to disable this?
Aug 18, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
