amvogel5
Jul 07, 2021Follower
Disable SSID Broacast
How do I disable the broadcast of the main or guest WiFi SSID on the RBK852 Obri Mesh system? This was very easy to do within the Orbi RBK50 system but does not seem to be available in the latest mod...
Jul 07, 2021Guru - Experienced User
Disabling of SSIDs is not supported on Orbi AX systems.
