Barryc49
Mar 13, 2023Aspirant
Disabling band steering on Orbi RBK752 router
I need to turn off Band Steering on my Orbi RBK752 router. I have searched the Netgear site as well as several others, and have looked through all the tabs on the router settings. Unfortunately I can...
Mar 14, 2023Guru - Experienced User
There isn't an option to disable it. Its part of the system and there isn't an option for removing it.
Maybe going over why you want to disable it can help more?
Barryc49
Mar 14, 2023Aspirant
Thank you for your reply. The reason that I want to disable is that we have a Wallbox Pulsar Plus electic car charger. We have an Android phone app that is connected to the Wallbox by Bluetooth. Updates to the app can only be made by connecting the phone to the Wallbox by Wi-Fi which we have been unable to do. The suppliers of the Wallbox informed us that the problem is caused by the use of band steering and advised us to disable it.
Whilst I have a basic understanding of the concept of band steering, I have never used a home electric car charger before.
- CrimpOnMar 14, 2023Guru - Experienced User
Thanks for providing the essential information (Wallbox Pulsar Plus Car Charger).
https://wallbox.com/en_us/wallbox-pulsar-plus
I have a feeling that the problem is stated incorrectly: "Updates to the app..." This is an Android app that was downloaded from Google Play. This app will be updated the same way it was installed in the first place: through Google Play. Perhaps the problem is instead that the app has provided a notification that there is new software for the charger itself.
It appears to me that the charger software can be updated without using WiFi at all (i.e. with Bluetooth):
If the issue is how to connect the charger to WiFi so that the app can reach the charger when not within Bluetooth range, my guess is that Band Steering is not the problem.
- Barryc49Mar 16, 2023Aspirant
Thank you for your comments. I shall try this.
