fsaurmann
Sep 15, 2021Tutor
Disabling Parental Controls on RBR850 From Web Interface
I'm looking for the parental controls settings in the web interface of the RBR850. It was enabled from the app, but I think it might be causing some problems with my server. I would like to disable i...
raven_au
Sep 15, 2021Virtuoso
fsaurmann wrote:I'm looking for the parental controls settings in the web interface of the RBR850. It was enabled from the app, but I think it might be causing some problems with my server. I would like to disable it, but it's unclear how to do it in the app and I'm not locating it in the web interface.
RBR850, Firmware 4.6.3.9
There is no entry in the Web UI for this.
It must be done from the app.
I haven't disabled them myself but I think what you need to do in the app is go to:
"home(top left corner)->Settings->Parental Control" and toogle the "Enable Smart Parental Controls" slider.
