fsaurmann
Sep 15, 2021Tutor
Disabling Parental Controls on RBR850 From Web Interface
I'm looking for the parental controls settings in the web interface of the RBR850. It was enabled from the app, but I think it might be causing some problems with my server. I would like to disable i...
fsaurmann
Sep 16, 2021Tutor
I figured I would share what I ended up doing here.
Essentially, I reset the router back to factory. When I would go into the app, I could not disable the parental controls from the settings panel. I'm not really sure what caused the lockup but it is fixed though in a round-about way.
Sep 16, 2021Guru - Experienced User
Was the Orbi app not showing the parental controls or the disable button?
Can you capture a screen shot of this and post it? Please use the Choose File button to attach it to your post.
- fsaurmannSep 16, 2021Tutor
I unfortunately did not take a screen cap of what the app was doing when attempting to disable.
