OneManTagTeam's avatar
Dec 09, 2022
Disappointed in Wi-Fi speeds with Orbi RBK852
I live in the UK and have BT Fibre 900 FTTP. The smart hub 2 which comes with it isnt Wi-Fi 6, so I was only getting 350-400 max with my Wi-Fi 6 devices. I switched the ASUS AX86U and immediately noticed the difference in my Wi-Fi speeds, getting 850-900 on regular basis.
Unfortunately during renovations, the router got damaged and wouldn’t work so thought I’d splash out on the Orbi kit with the 2 satellites as all the reviews rave about the speeds achievable with Wi-Fi 6.
However, the speeds I’m getting on my Wi-Fi 6 devices is only around 400, around the same as I was getting using BT’s Smart Hub 2.
Are there any settings I can change to get closer to 900 I was getting with the ASUS?
If this speed is all that’s achievable, I’ll be getting a refund ASAP
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    What devices are you speed testing with. Some device may only be limited by there design and support of 2x2. Most max out at 500-700Mpbs on 5Ghz AX. If you had 4x4 supporting devices, then you should see near 900mpbs.
    Are you speed testing wirelessly with the RBS turned off?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channels are you using? Auto? Try channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has Armor, SPC or Traffic Meter featured been enabled?
