carlsson
Sep 07, 2023Star
Disappointed with coverage of AX6000 / RBS850
I just installed a RBS850 / AX6000 Mesh system with one router and two satellites. I previously had an RBK50 system with 3 satellites that worked good, but I needed more satellites and was told that ...
Sep 08, 2023Guru - Experienced User
The distance between R and S1 is TOO Close. 30 feet is starting distance between the RBR and a RBS.
For that size of home the R and one RBS should work but you seem to have blocking building materials in the center.
Wondering if a Power Line adapter to connect S2 RBS to the RBR and turn OFF S1 RBS would be better.
Might update to this as well:
Comes highly recommended.
- carlssonSep 08, 2023Star
What's a Power Line adapter, and should that really be necessary? (I don't want to draw cables in this old house, it's not made for that, hence the Mesh solution)
I'll try to just disconnect S1 and see what happens.
Eventually I will have my home office in the attic, then they will even be more separated.
I thought I had the latest firmware, since it updated when I installed it yesterday. But I see now that I have version 4, and the URL you provided has v7… 😬
So manual update then?
Thanks again!
- FURRYe38Sep 08, 2023Guru - Experienced User
