BPDriscoll60
Sep 20, 2024Aspirant
Disneyplus.com blocked
Recently, I have not been able to access Disneyplus.com on any device connected to my Orbi network, either WiFI or hard-wired. However, I can use my phone's Wireless connection to access Disneyplus.c...
- Sep 20, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
BPDriscoll60
Hello,
I checked the IP v6, and it was set to 6to4. I changed it to Autodetect and then put it in DHCP. I tested DisneyPlus.com, and I was able to get connected. I did change the IP v4 DNS setting to CloudFlare in my early troubleshooting, but that didn't resolve anything. I think we are good for now. Thank you for your assistance.
Sep 20, 2024Guru - Experienced User
Enjoy. 📡
