Ace321
Aug 18, 2020Apprentice
DNS errors RBK753
I have occasional DNS errors and reloading the page resolves it. Here is the link for details from other people who had same issue but no resolution was provided. Any ideas? https://community.net...
eliea
Sep 01, 2020Aspirant
I am having the same issue and spent tons of time with support with no luck.
Before the newer version a support guy acknowledged it is a firmware issue and asked me to change ORBI to AP mode and the issue went away. Definitely with AP mode lots of functionality won’t be available including armor (armor is free for a year with Costco version). The guy promised that the issue will be solved after the firmware upgrade of Mid August.
I reverted back the AP mode to router mode and the issue is worst then before, tried all what you guys mentioned and nothing worked except AP mode. Spent again lots of time on the phone with support and no luck at all, and they never acknowledged after the latest firmware that this is a know issue.
Not sure what else can be done.
campolo313
Sep 02, 2020Apprentice
Out of curiosity, who is your ISP? I have Comcast and use OpenDNS as my DNS Servers, and I haven't had a single DNS Error and I have the same system as you, RBK753S from Costco with Armor Enabled. I can't imagine it being purely a firmware issue if I'm not having the same issues, it must be a combination of the DNS and Firmware.
- Ace321Sep 02, 2020ApprenticeI have same setup as you with Comcast. Tried these DNS as well. Swapped even with different router from Costco and still issue. Worked with NG and no resolution.
- FURRYe38Sep 02, 2020Guru - Experienced User
What happens if you disable Armor on your system, factory reset and don't enable Armor this time. Do you still see problems.
Been many other posts about Armor causing DNS and connection problems.
campolo313 wrote:Out of curiosity, who is your ISP? I have Comcast and use OpenDNS as my DNS Servers, and I haven't had a single DNS Error and I have the same system as you, RBK753S from Costco with Armor Enabled. I can't imagine it being purely a firmware issue if I'm not having the same issues, it must be a combination of the DNS and Firmware.
- Ace321Sep 02, 2020ApprenticeYes I tried that option as well with NG support.
- elieaSep 02, 2020Aspirant
After doing a factory reset Armor is enabled by default, I am not sure if there is a way around that.
FURRYe38 wrote:What happens if you disable Armor on your system, factory reset and don't enable Armor this time. Do you still see problems.
tired disabling Armor and issue remains.
- campolo313Sep 02, 2020Apprentice
I don't think it would necessarily be Armor, I have Armor Enabled and don't have the issues.
