Ace321
Aug 18, 2020Apprentice
DNS errors RBK753
I have occasional DNS errors and reloading the page resolves it. Here is the link for details from other people who had same issue but no resolution was provided. Any ideas? https://community.net...
Sep 02, 2020Guru - Experienced User
What happens if you disable Armor on your system, factory reset and don't enable Armor this time. Do you still see problems.
Been many other posts about Armor causing DNS and connection problems.
campolo313 wrote:Out of curiosity, who is your ISP? I have Comcast and use OpenDNS as my DNS Servers, and I haven't had a single DNS Error and I have the same system as you, RBK753S from Costco with Armor Enabled. I can't imagine it being purely a firmware issue if I'm not having the same issues, it must be a combination of the DNS and Firmware.
eliea
Sep 02, 2020Aspirant
After doing a factory reset Armor is enabled by default, I am not sure if there is a way around that.
FURRYe38 wrote:What happens if you disable Armor on your system, factory reset and don't enable Armor this time. Do you still see problems.
tired disabling Armor and issue remains.
