Ace321
Aug 18, 2020Apprentice
DNS errors RBK753
I have occasional DNS errors and reloading the page resolves it. Here is the link for details from other people who had same issue but no resolution was provided. Any ideas? https://community.net...
Sep 12, 2020Guru - Experienced User
Please keep in contact with NG support about this. Not much else we can do here in the forums.
Ace321 wrote:My NG support ticket was escalated and will be forwarded that to engineering. I have been collecting logs for sending to NG engineering. Suprisingly they did not hear this issue from that many customers. I think they should monitor their communities as well. Hopefully we will have a fix soon.
Nnyan
Sep 17, 2020Tutor
Having the same issues with my RBK753. Have had various mesh and hardwired systems (Plume, Ubiquiti, Nest, Eero...) and have not had this issue (with the exception of a few bad UBNT firmware versions that were fairly quickly resolved). I have factory reset and tried a number of DNS options (including Comcast DNS). It affects wired and wireless clients seemingly randomly. It mostly affects the first time you go to a website but I have seen it happen to websites you have visited in the past. The error message is quick and then the page loads. Browsers do not affect the issue and all browsers are not running cached.
I don't have enough data on this but it seems that secured sites are affected more then unencrypted. I have also removed my PA-220 out of the loop and no effect.
- FURRYe38Sep 17, 2020Guru - Experienced User
What happens if you use the ISP Modem in router mode and the RBR in the modems DMZ?
I don't have enough data on this but it seems that secured sites are affected more then unencrypted. I have also removed my PA-220 out of the loop and no effect. - NnyanSep 17, 2020Tutor
I will have to try that but I did have the modem in router mode and the Orbi's in AP mode for almost a week when Comcast was sending me a new gateway and I don't recall having the problem then.
So your ISP gave you a different modem gateway?
- NnyanSep 19, 2020Tutor
They upgraded me to the latest Advanced Gateway. But I eliminated this as the issue as it works with other routers (not getting the weird dns errors).
- FURRYe38Sep 19, 2020Guru - Experienced User
I would keep in touch with NG support about this. Maybe something with Orbi AX and your ISP service that needs to be looked into. I don't see this with mine, though I'm on a different ISP and use a different modem.
Nnyan wrote:They upgraded me to the latest Advanced Gateway. But I eliminated this as the issue as it works with other routers (not getting the weird dns errors).
- elieaSep 24, 2020AspirantNG are not responding to my case. After few calls It was escalated to L1 and still no response. And each time I call I have to go through the helpdesk then to the orbi team then the orbi team has to transfer me to the orbi ax team. Each time it is a 45 minutes wait.
- Retired_MemberSep 25, 2020
If you are familiar with using telnet to access your router you could test my workaround to check if the issue is the same
I have no dnsissus running for days now.
- MstrbigSep 25, 2020Master
No DNS issues here as well.
Regarding the reported issues, it could be device issues. If a PC flush DNS, then set back up as DHCP. Because if one is using a static IP and the problem went away, flushing DNS may solve it. Also try resetting the network on the device.
Also DNSbenchmark is not totally accurate as the benchmarks will change daily, depending on traffic. Opendns is usually the slowest here. So it is best sometimes to use the ISP DNS servers as they have less overhead.
One thing we are also doing now is enabling IPv6 and using a 3rd party IPv6 DNS. Several websites have gone to this and most ISPs do not support it. So this is a good way to support it on the user level. Then you can test it to see if it is working.
- FURRYe38Sep 25, 2020Guru - Experienced User
You'll need to keep in touch with them, even if it takes a while to get online with them.
You can make contact with a forum moderator as well.
All in all, changes will take time to make if this is to be fixed. Will not happen over night.
Try the telnet option if your confortable with that. Have one of the users help you with that. Might ask them to help you via Teamviewer.
eliea wrote:
NG are not responding to my case. After few calls It was escalated to L1 and still no response. And each time I call I have to go through the helpdesk then to the orbi team then the orbi team has to transfer me to the orbi ax team. Each time it is a 45 minutes wait. - FURRYe38Sep 25, 2020Guru - Experienced User
I used to use Googles Nambbench years ago. However it kept saying my ISP has the fastest DNS so I've always used ISP DNS. I have tired quad 1 and 9 on occasion. Have not seen any DNS issues on my Orbi AX. Seems like this maybe a ISP DNS handling issue with some specific ISPs possibly or Orbi AX mis-configuration.
Mstrbig wrote:No DNS issues here as well.
- elieaSep 26, 2020AspirantSenior advanced Technical support called yesterday and they said I did all possible solutions that they can think of. They will consult with higher team and get back to me today.I’ll keep you guys posted.
- Ace321Sep 26, 2020Apprentice
Ok keep us posted. NG Sr. Support Engineer could not resolve it for me. She asked me to captured the logs and attach to my ticket. After I completed that step I was told that logs are forwarded to enineering. No news after that.
- FURRYe38Sep 26, 2020Guru - Experienced User
Thank you for letting us know. Glad NG seems to be working on this.
eliea wrote:
Senior advanced Technical support called yesterday and they said I did all possible solutions that they can think of. They will consult with higher team and get back to me today.I’ll keep you guys posted. - ManuilTonevFeb 03, 2021Tutor
Hi, did you get anywhere with support on this? I have been getting ERR_CONNECTION_RESET errors intermittently ever since I switched from the WiFi of my ISP model to the WiFi on my Orbi RBR750 in October last year.
- FURRYe38Feb 03, 2021Guru - Experienced User
ManuilTonev wrote:Hi, did you get anywhere with support on this? I have been getting ERR_CONNECTION_RESET errors intermittently ever since I switched from the WiFi of my ISP model to the WiFi on my Orbi RBR750 in October last year.
Hi,
I have firmware v3.2.16.6_1.4.4 on the Orbi router.
My ISP is Optimum Online.
The router model is: ALTICEONE_B58B
Thanks,
Manuil
Have you update to v12 to see if that version changes anything?
Cant find any informaton on the modem model. Is that the model number printed on the sticker on the modem?
Thanks,
Manuil
Thanks. I just updated to 3.2.17.12 but the problem persists.
Optimum does not share much details on their box (maybe built/white labeld for them) but it is the one on this page: https://www.optimum.com/alticeone
I got the exact model from the Technical Information menu (press the Altice button on the cable remote, navigate to settings, technical info).
Here are pictures of what it looks like:
Meanwhile, I talked to customer support for NG. They walked me through installing the 3.2.17.12 FW update and let me with instructions for performing a hardware reset, suggesting that I did not properly instlal the router (never mind I followed the app installation instructions to the t). I will try that as a next step but I am not holding my breath - the problem was there from the moment I turned on the Orbi router.
Possibe your ISP modem has a built in router...
ManuilTonev wrote:Thanks. I just updated to 3.2.17.12 but the problem persists.
Yes but why would that be a problem? Each web request goes through a number of routers at each hop to the destination. When I connect directly to the cable box's wifi, there are no problems. But when I go through the NG router that is wired to the cable box, then hickups appear. What could be clashing between the two?
I wish I had another network to test if the NG will work fine if not connected to the Altice.
Thats a problem, having more then 1 router on the same line in the home can cause problems.
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou might try option#2 first...
- elieaFeb 03, 2021AspirantAlready tried the path through and it did not work. Orbi support are still working on the issue they already asked me to try lots of things with no luck. Case was open with orbi support since September and so far no resolution.
You'll need to keep in contact with NG support. Keep on them about this.
- elieaFeb 03, 2021AspirantI am on top of it
- ManuilTonevFeb 04, 2021Tutor
Thank you so much. I got Optimum to enable Bridge mode, the Orbi got a public IP but the issue still persist. I.e. not related to the double NAT-ing but likely a router issue (since it does not happen if I connect to the ISP Box's network/WiFi or I tether through my phone's data).
Meanwhile, the ISP seems to have their own range extender smart wifi solution. I will give that a try and, if it works, will cut my losses with the NetGear and return it to Costco.
