Ace321
Aug 18, 2020Apprentice
DNS errors RBK753
I have occasional DNS errors and reloading the page resolves it. Here is the link for details from other people who had same issue but no resolution was provided. Any ideas? https://community.net...
Feb 03, 2021Guru - Experienced User
Have you update to v12 to see if that version changes anything?
Cant find any informaton on the modem model. Is that the model number printed on the sticker on the modem?
ManuilTonev wrote:Hi,
I have firmware v3.2.16.6_1.4.4 on the Orbi router.
My ISP is Optimum Online.
The router model is: ALTICEONE_B58B
Thanks,
Manuil
ManuilTonev
Feb 03, 2021Tutor
Thanks. I just updated to 3.2.17.12 but the problem persists.
Optimum does not share much details on their box (maybe built/white labeld for them) but it is the one on this page: https://www.optimum.com/alticeone
I got the exact model from the Technical Information menu (press the Altice button on the cable remote, navigate to settings, technical info).
Here are pictures of what it looks like:
Meanwhile, I talked to customer support for NG. They walked me through installing the 3.2.17.12 FW update and let me with instructions for performing a hardware reset, suggesting that I did not properly instlal the router (never mind I followed the app installation instructions to the t). I will try that as a next step but I am not holding my breath - the problem was there from the moment I turned on the Orbi router.
- FURRYe38Feb 03, 2021Guru - Experienced User
Possibe your ISP modem has a built in router...
ManuilTonev wrote:Thanks. I just updated to 3.2.17.12 but the problem persists.
- ManuilTonevFeb 04, 2021Tutor
Yes but why would that be a problem? Each web request goes through a number of routers at each hop to the destination. When I connect directly to the cable box's wifi, there are no problems. But when I go through the NG router that is wired to the cable box, then hickups appear. What could be clashing between the two?
I wish I had another network to test if the NG will work fine if not connected to the Altice.
- FURRYe38Feb 04, 2021Guru - Experienced User
Thats a problem, having more then 1 router on the same line in the home can cause problems.
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou might try option#2 first...
- elieaFeb 04, 2021AspirantAlready tried the path through and it did not work. Orbi support are still working on the issue they already asked me to try lots of things with no luck. Case was open with orbi support since September and so far no resolution.
You'll need to keep in contact with NG support. Keep on them about this.
- elieaFeb 04, 2021AspirantI am on top of it
Thank you so much. I got Optimum to enable Bridge mode, the Orbi got a public IP but the issue still persist. I.e. not related to the double NAT-ing but likely a router issue (since it does not happen if I connect to the ISP Box's network/WiFi or I tether through my phone's data).
Meanwhile, the ISP seems to have their own range extender smart wifi solution. I will give that a try and, if it works, will cut my losses with the NetGear and return it to Costco.
- DNS_PROBE_FAILMar 08, 2021Luminary
Furry is 100% correct. You need to call Netgear support and tell them to fix this. That is the only way this will get resolved is if enough people complain.
The issues are very well documented and my support case has proven it to them, while they were connected to my computer. I could recreate it fairly easily and make it go away by switching to IPv6 but that doesn't help the devices on the network that are IPv4 only.
Please call NG support and make them fix their bad firmware.
- ManuilTonevMar 08, 2021Tutor
100% agree - NG needs to get their act together on this.
On my part - I am retunring my NG, not worth my time and efforts anymore. After wasting several hours on the phone with their support just to upgrade firmware with no benefit, I pulled the plug. I have switched to my ISP's (Optimum) mesh network solution and it works comparably well without the annoyances of NG denying to serve web pages at random.
- FURRYe38Mar 08, 2021Guru - Experienced User
Good luck.
