Validus
Jan 28, 2021Luminary
DNS Probe finished nxdomain & missing router logs
I have a RBK853 — Orbi WiFi 6 System AX6000 model, which is working fine, but has a couple of bugs? 1 router + 2 satellites with currently version 3.2.16.22 firmware on each. The first issue:...
- Mar 31, 2021
Work around fix for now.
Under your router admin > advanced > advanced > IPv6
I changed the Internet Connection Type from "Disabled" to "6to4Tunnel", the rest I just left as automatic, applied and also rebooted the PC.
Jan 28, 2021Guru - Experienced User
Have you tried v12?
FYI about DNS:
- ValidusJan 30, 2021Luminary
It's the Model RBK853 - Orbi WiFi 6 System AX6000, which showed Firmware version 3.2.16.22 as the latest, when checking under the auto-update of the router login.
Odd how it's listed for RBK852 but not the RBK853. I think I will manually update to Firmware Version v3.2.17.12 anyways in case they just missed updating that and suggests there is a security fix too. Thanks, seems to work fine upon the router and both satellites so far!
Will update later if resolved these issue or not.
- FURRYe38Jan 31, 2021Guru - Experienced User
What is the mfr and model# if your ISP Modem or ONT?
Keep us posted...
Validus wrote:It's the Model RBK853 - Orbi WiFi 6 System AX6000, which showed Firmware version 3.2.16.22 as the latest, when checking under the auto-update of the router login.
- ValidusFeb 01, 2021Luminary
It's a Chorus Model Type 200 Optical Network Terminal fiber connection connected via ethernet to the Orbi RBK853. It has a VLAN / Bridge setup with ID 10, if that matters as well?
The firmware to version 3.2.17.12 was successful and runs fine, but doesn't appear to of resolved the issues. The DNS Probe finished nxdomain is not appearing as much as it did. It's very rare or gone away now? Hard to find a website which does it.
