Validus
Jan 28, 2021Luminary
DNS Probe finished nxdomain & missing router logs
I have a RBK853 — Orbi WiFi 6 System AX6000 model, which is working fine, but has a couple of bugs? 1 router + 2 satellites with currently version 3.2.16.22 firmware on each. The first issue:...
- Mar 31, 2021
Work around fix for now.
Under your router admin > advanced > advanced > IPv6
I changed the Internet Connection Type from "Disabled" to "6to4Tunnel", the rest I just left as automatic, applied and also rebooted the PC.
Jan 28, 2021Guru - Experienced User
Have you tried v12?
FYI about DNS:
Validus
Jan 30, 2021Luminary
It's the Model RBK853 - Orbi WiFi 6 System AX6000, which showed Firmware version 3.2.16.22 as the latest, when checking under the auto-update of the router login.
Odd how it's listed for RBK852 but not the RBK853. I think I will manually update to Firmware Version v3.2.17.12 anyways in case they just missed updating that and suggests there is a security fix too. Thanks, seems to work fine upon the router and both satellites so far!
Will update later if resolved these issue or not.
- FURRYe38Jan 31, 2021Guru - Experienced User
What is the mfr and model# if your ISP Modem or ONT?
Keep us posted...
Validus wrote:It's the Model RBK853 - Orbi WiFi 6 System AX6000, which showed Firmware version 3.2.16.22 as the latest, when checking under the auto-update of the router login.
- ValidusFeb 01, 2021Luminary
It's a Chorus Model Type 200 Optical Network Terminal fiber connection connected via ethernet to the Orbi RBK853. It has a VLAN / Bridge setup with ID 10, if that matters as well?
The firmware to version 3.2.17.12 was successful and runs fine, but doesn't appear to of resolved the issues. The DNS Probe finished nxdomain is not appearing as much as it did. It's very rare or gone away now? Hard to find a website which does it.
- ValidusFeb 03, 2021Luminary
So are these bugs that has been around for quite a while and affects a bunch with this certain mesh router, but no one has any clue how to resolve it?
Is there any information you might need to help?
- Domain Name Server (DNS) Address is set and everything else is automatic
- WAN Preference is Internet Port (2.5 Gbps)
- Enable AX is on
- Disable IGMP Proxying is ticked
- RIP Direction is both
- RIP Version is disabled
- Use Router as DHCP Server is ticked
- NTP Settings is set
Do I use Router or AP Mode? Currently it's on Router
- Guest Network is disabled
- E-mail Notification is Off
- No Port Forwarding
- No Dynamic DNS
- No VPN Services
- No Static Routes
- Remote Management is disabled
- UPnP is disabled
- IPv6 is disabled
- Traffic Meter is disabled
- VLAN / Bridge Settings is enabled (VTAG ID = 10 / PRIORITY = 0 / ALL)
