ssylvan
Dec 03, 2020Guide
DNS_PROBE_FINISHED_NXDOMAIN errors on RBR850
So I've noticed that when I use my Orbi in router mode, I get a lot of DNS_PROBE_FINISHED_NXDOMAIN errors in chrome. The error flashes for a bout a second and then the page loads. This happens a coup...
CrimpOn
Dec 03, 2020Guru - Experienced User
ssylvan wrote:So I've noticed that when I use my Orbi in router mode, I get a lot of DNS_PROBE_FINISHED_NXDOMAIN errors in chrome. The error flashes for a bout a second and then the page loads. This happens a couple of times per day.
Anyone have any ideas what this is about? I don't see anything in logs relating to this.
I guess you have already looked at suggestions like these:
https://www.hostinger.com/tutorials/fix-dns_probe_finished_nxdomain
ssylvan
Dec 04, 2020Guide
Yes. None of that stuff helps. The issue is 100% isolated to the Orbi itself.
- internet-johnJan 13, 2021Guide
I'm having the same problem. Did you ever figure out a solution?
- FURRYe38Jan 13, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What browser are you using?
Is IPv6 enabled on the RBR?
internet-john wrote:I'm having the same problem. Did you ever figure out a solution?
- internet-johnJan 14, 2021Guide
I switched the DNS servers to use google's (8.8.8.8 and 8.8.4.4) and it seems to have resolved the issue for now (hopefully for good).
I'm using firmware v3.2.16.22_1.4.9 and Chrome browser. IPv6 is disabled.
