ssylvan
Dec 04, 2020Guide
DNS_PROBE_FINISHED_NXDOMAIN errors on RBR850
So I've noticed that when I use my Orbi in router mode, I get a lot of DNS_PROBE_FINISHED_NXDOMAIN errors in chrome. The error flashes for a bout a second and then the page loads. This happens a coup...
internet-john
Jan 15, 2021Guide
It's the AT&T Arris BGW210-700.
Jan 15, 2021Guru - Experienced User
Orbi in router or AP mode behind the ATT modem. This modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
internet-john wrote:It's the AT&T Arris BGW210-700.
- internet-johnJan 16, 2021Guide
Thanks! I switched the router to IP Passthrough mode (the closest thing to bridge mode available for the BGW-210). I'll see if it makes a difference.
- FURRYe38Jan 21, 2021Guru - Experienced User
Anyone with a 8 series Orbi wanna try this?
- Ace321Jan 21, 2021ApprenticeTry this. I have Beta version (similar version number) on 7 series and my dns issues seem to be resolved
