Ziz
May 30, 2020Follower
Do I need a modem?
I just purchased my orbi. I do not need a modem with my internet company but the orbi is asking for a modem. Do I have to have a modem or can I get around that?
May 30, 2020Guru - Experienced User
Depends on what your isp uses or how they connect.
Some have their own routing setup like in apartments.
Some are ONT's that are just gateways. Some ONT's have a router built into them.
You dont have to have a modem but you do have to contact your isp to see what the best way to hook a router to their setup is.
