CBrown_73
Dec 12, 2023Aspirant
Does anyone have an idea of when NetGear may be releasing the firmware updates?
Does anyone have an idea of when NetGear may be releasing the firmware updates? Seems like it's been a while and with new attacks, daily, seems like NetGear would be releasing a little more frequentl...
- Dec 12, 2023
That's not current FW.
CBrown_73
Logged into the router now and it shows current firmware V6.3.7.10
Dec 12, 2023Guru - Experienced User
- CBrown_73Dec 12, 2023Aspirant
Downloaded and installed the firmware listed. Everything is working fine. Appreciate your help!!
- FURRYe38Dec 12, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
