BarbF
Oct 11, 2023Aspirant
Does anyone have experience with a CR1000A router and an RBR850?
CrimpOn
Oct 11, 2023Guru - Experienced User
If there is a specific question, that might help attract more attention. Is there a Verizon user forum which might be more likely to turn up someone who has this specific Verizon model?
- BarbFOct 12, 2023Aspirant
Verizon wants to upgrade my router and I am concerned that there will be a compatibility issue between the CR1000A and the RBR850. Has anyone used the 2 of them together. I love my orbi as well.
- FURRYe38Oct 12, 2023Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
