ultradeepfiled's avatar
Sep 26, 2023
Does anyone have problems with openvpn? It suddenly stop working!
I’m using RBK853, and updated firmware to 7.2.6.21_5.0.20 a few days ago.
I’ve been using vpn service without any problem for about two years.
I even used it flawlessly a couple of hours ago.
About 30 minutes ago, it suddenly stopped working after I didn’t do anything…
The error I found in the log file is “server poll timeout”, meaning, in my knowledge, my router is unreachable.
I rebooted router, still no luck.
I redownloaded the config file but didn’t work.
I checked my DDNS status and found no problem.
Does anyone has a same problem?
  • Something to contact OpenVPN about and see if there are any issues with there services.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • FURRYe38's avatar
