Ramakay
Mar 23, 2021Aspirant
Does Netgear have an ombudsman to escalate issues ?
Despite an RMA and 6+ months of back and forth - I have received no resolution to my issue - because of the delaying tactics and slow responses via engineering, L2 support I am out of the window to di...
energie
Mar 23, 2021Luminary
If the issue is the 'wireless speed' you're getting with that router. I think you are hitting the limit already with that router.
I might be wrong though, however 300-400 Mbps wireless with AC seems to be pretty decent. In any case the router you are using is a Wifi 5 (AC) router, so it doesn't matter that you use client that are wifi 6 (AX) capable, the bottleneck remains the router.
I am sure Netgear support must have said this. They can't be that bad right, keeping you months on support and doing pointless RMA's.
The forum you are now in is for Wifi 6 (AX) btw.
