ricolah's avatar
ricolah
Does Orbi supports Emojis for RBK852 and RBK752?
Hi, does current firmware in Orbi RBK852 (AX6000) and Orbi RBK752 supports Emojis 🚍🚁🚀🌋 in SSID? I am thinking of switching to Orbi from Google router and Asus which both supports currently.
  • No.
    Some devices don't suppott emojies in there wifi system so if you put emojis in the SSID name, those devices wouldn't be able to connect.
  • FURRYe38's avatar
    No.
    • ricolah's avatar
      ricolah
      Sigh. I guess I will stick to current brand that supports. I don't have devices now that doesn't accept emojis. My mobile, sonos, laptop works properly emojis SSID.
      • FURRYe38's avatar
        I presume most older devices don't.
        Good Luck.
