checkyourmirror
Feb 09, 2025Aspirant
Does the Orbi 960 support Thread Devices
I am wanting to add a Smartlock with Thread however I am a little confused if I need my Mesh network to support Thread. I read that the 960 does not support thread however I do have an Apple TV 4K wh...
Feb 10, 2025Guru - Experienced User
Check with the Mfr of the device to see if the device will connect to a standard wifi signal, SSID name and password.
There is a separate IoT network configuration on Orbi systems that you can connect IoT devices too.
- FURRYe38Feb 10, 2025Guru - Experienced User
and:
https://level.co/matter-smart-lock-guide/#compatiblehubs
These all see to be specific to the device and have there own hubs to pick from that are compatible.
