Rikerrock
Jun 11, 2020Tutor
Does the orbi wifi 6 work with the rbs20 or rbs50 units all connected via ethernet wire?
Will these older addons work with the new orbi 6 mesh system connected via hard wire? I saw a mesh system from costco and was considering getting it. Also, are people finding better speed etc with ...
Jun 11, 2020Guru - Experienced User
Yes you can ethernet connect Orbi AC RBS to Orbi AX though you may need incorrect status on the RBRs Ui.
