Les62
Aug 23, 2021Aspirant
Does the RBK352 — Orbi AX1800 WiFi 6 allow setting of Tagged VLAN ID in the WLAN Interface
Hi, Thinking of buying a RBK352 — Orbi AX1800 WiFi 6 Dual-band Mesh System 2 pack but need to know if it allows setting of a tagged VLAN id on the WLAN interface as required by my ISP? Have goog...
Aug 23, 2021Guru - Experienced User
Page 74 of the manual goes over setting them up. You can read and see if those would cover your specifics.
