lavamat
Jun 20, 2021Follower
Does the RBR 850 work at all?
Hi, Has anyone successfully gotten the RBR/RBS 850 to work? Have had one RBR 850 and two RBS 850 now for over a year and they never worked properly. I have about 40 WiFi clients at home and at least ...
Jun 21, 2021Guru - Experienced User
Mine been working since I got mine back in 2019.
There maybe some settings and placement that needs to be reviewed.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
lavamat wrote:
Hi,
Has anyone successfully gotten the RBR/RBS 850 to work? Have had one RBR 850 and two RBS 850 now for over a year and they never worked properly. I have about 40 WiFi clients at home and at least 10 of them get disconnected every 10min and then need about the same time to reconnect. I have invested about 200h+ to try all possible settings, making changes every day, but failed to get it to work. I am now about to throw everything away, but wanted to check, if anyone had a positive experience with these products. (I am developing WiFi systems firmware professionally, so I believe I know what I am talking about).
Thank you!
