mcgixxer
Jun 27, 2020Follower
Does WIFI 6 satelite work with RBR50 if wired
I see on the product page that RBS850 only works with a wifi-6 router, but what If I want to add my satellite wired? Would this WIFI6 orbi satellite still work with the mesh network if it was hooked ...
CrimpOn
Jun 29, 2020Guru - Experienced User
Thanks for the detailed explanation. My guess is that the AX satellite "Daisy Chained" through the AP mode Orbi to the RBR850 router.
It appears to me that this could be a reasonable solution to this specific situation. I would certainly want to purchase from someplace that has a generous return policy. (Amazon, Costco, etc.)
Ya, I presume if the RBR50 was in router mode the RBS850 would or should connect when wire connected to the RBR50. Seems ok and as the RBS50 work in same manor with the RBR850 when wire connected. There just not wirelessly compatible at this time.
