LVJRich
Mar 13, 2020Tutor
Double NAT / Strict NAT
I am at my wits end! We have three XBox consoles in my home and all three keep getting a Double NAT or Strict NAT condition. I have turned on UPnp and IPV6 to no avail. I have a Motorola MB8600 modem ...
LVJRich
Mar 13, 2020Tutor
No, haven't done a factory reset yet. We just upgraded to Cox GigaBlast, replaced my old Arris Surfboard with the new Motorola, and replace my old Orbi system with this new RBR850. Several problems so far but this is the one it the first on the list.
Mar 13, 2020Guru - Experienced User
Power ON all three game consoles. When they are ready, hold the front power buttons until they turn OFF. Leave them off. Then I would power OFF the modem for 30 seconds then back ON. WHile this is happening, press the reset button in back of the RBR for 15 seconds then release. Walk thru the setup wizard and complete the setup. Reset the RBS as well.
Be sure to check CTS and RTS values. If you see 64, change both radios to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
Power ON one xbox at a time and check NAT status on the dashboard networking settings.
Are the game consoles wired or wireless?
