LVJRich
Mar 13, 2020Tutor
Double NAT / Strict NAT
I am at my wits end! We have three XBox consoles in my home and all three keep getting a Double NAT or Strict NAT condition. I have turned on UPnp and IPV6 to no avail. I have a Motorola MB8600 modem ...
LVJRich
Mar 19, 2020Tutor
So since the new FW was updated last night I am very happy to report that everything was stable last night and been going strong since. Although I am still getting double NAT / Strict NAT, the disconnects every 20 minutes seems to have been solved.
I will work on fixes for the NAT issues but the disconnects that were driving me nuts has gone away.
Mar 19, 2020Guru - Experienced User
Is the NAT issue with the RBS being online and the consoles connecting thru it or directly to the RBR?
- LVJRichMar 19, 2020TutorI get it on all three consoles. My son is telling me that a workaround to the issue is to go into XBox settings and manually changing the port. Not ideal but it seems to work.
One console hard wired to RBR.
One console hard wired to RBS.
One console through RBS wifi. - FURRYe38Mar 19, 2020Guru - Experienced User
Ok, possible uPnP issued between Orbi and the consoles. I know I have two however they are one separate networks.
Do manually changing ports on each gets OPEN NAT on each of the consoles?
- LVJRichMar 19, 2020TutorYes, after changing ports manually (he keeps selecting random ports until NAT shows open) it works. He has done this on all three consoles.
Like I said, it's not ideal and we've never had to do this before, but it IS a working work-around. - FURRYe38Mar 20, 2020Guru - Experienced User
OK, great information. I'll forward this on the NG. I know there is some problems with xbox NAT and Orbi AX. This is a uPnP and NAT Filter issue. NAT Filter set to OPEN would be helpful unfortunately it's not working at the moment. I think once NG gets that fixed, then you won't have to manually set ports on consoles.
- LVJRichMar 20, 2020TutorExcellent, my son is a smarter guy than I am and he has a much larger interest in the XBox working than I do. If there is any further info that we could provide that might help NG just let me know.
Of course. Having two xboxes here is important to have good working systems. NAT status and CoD is priority. :smileyvery-happy:
I posted a link to this in the bug report I have going and gave some feedback. Hoping NG will look into this.
