wfletchb99's avatar
Feb 16, 2021
Double NAT on wired. Open NAT on wifi
I know the Double/Strict NAT general topic has been beaten to death, but I could not find a situation matching mine.   Recently replaced my R7000 with this RBK752.  No issues except for the one men...
  • FURRYe38's avatar
    Xbox has always been problematic when it comes to NAT status. Disable all Instant ON features. This was one problem Xbox 1 had a few years ago. Not sure if it was ever addressed by MS.
    2nd, do not do 30/30/30 resets on Orbi. 15 second button press is only needed on Orbi systems.
    You shouldn't need any PF or Port Triggering configurations. You only need uPnP enabled and thats its. IF you have two game consoles, you can set NAT Filter to Open if you use both consoles online at the same time. I'd try setting a IP address reservation for your consoles ON the RBR router.
    After making router changes and the RBR reboots. Press and hold the front power button on the xbox console until it shuts off. Then turn it back on.
