devdeep
Aug 31, 2022Guide
Double net and ip addresses allocation
I am confused by who allocates isp addresses. Connection is: ONT--> isp router--> my router ("X")
Isp router does not allow DHCP switch off and is necessary to connect my phone to it.
1. If I let the isp router handle ip addressing, to avoid resetting all devices on my current router (X), can I give the isp router the same SSID as X? X has ethernet wired switches - will the same name cause issues?
2. If I turn off WiFi in the isp router, presumably X will provide the ip addresses (as it is now). I can ignore other ethernet ports in the isp router so only address given by it is the X ip address.
3. In 2 above, any other double net issues I need to consider?
1. If I let the isp router handle ip addressing, to avoid resetting all devices on my current router (X), can I give the isp router the same SSID as X? No. X has ethernet wired switches - will the same name cause issues? Yes.
2. If I turn off WiFi in the isp router, presumably X will provide the ip addresses (as it is now). I can ignore other ethernet ports in the isp router so only address given by it is the X ip address. Yes.
3. In 2 above, any other double net issues I need to consider? Use the ISP routers DMZ to help avoid double NAT issues or configure AP mode on the X router leaving the ISP router to handle all router duties.
