TimCakir
Nov 19, 2022Star
Downgrade and then disable auto update rbr750
Hey guys, abour a year ago I was lucky to find an amazing post on how to downgrade to a stable firmware and disable auto update. It worked for around a year until I moved and made the mistake to fa...
Nov 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Current and last version of FW now supports disabling of Automatic Updates...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- TimCakirNov 25, 2022Star
Hey, ive tried it all, its the same as last year and I have enough of wasting hours of my life on making this netgear boxes work.
Do you remember that article? about downgrading to 3. something version? That had worked wonders until I made a mistake and factory resetted it all.
Please?
That was the solution, you were in that discussion it was September last year.
Please
- FURRYe38Nov 25, 2022Guru - Experienced User
Disabling of FW updates is only supported if v4.6.9.11 and beyond.
Orbi 7 and 8 systems work on this version of FW.
- MichaelCLDec 22, 2022Aspirant
I'm having the same issue...
The RBR750 is dropping the internet connection on wired and wireless every few minutes. I updated bot the RBR and RBS750 to the latest firmware. It seems to be less frequent, but it's dropping every 10-20 min now. I know it's the Orbi as I have a stable connection to the built in wifi of my cable modem.
