TimCakir
Nov 19, 2022Star
Downgrade and then disable auto update rbr750
Hey guys, abour a year ago I was lucky to find an amazing post on how to downgrade to a stable firmware and disable auto update. It worked for around a year until I moved and made the mistake to fa...
Nov 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Current and last version of FW now supports disabling of Automatic Updates...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
TimCakir
Nov 25, 2022Star
Hey, ive tried it all, its the same as last year and I have enough of wasting hours of my life on making this netgear boxes work.
Do you remember that article? about downgrading to 3. something version? That had worked wonders until I made a mistake and factory resetted it all.
Please?
That was the solution, you were in that discussion it was September last year.
Please
- FURRYe38Nov 25, 2022Guru - Experienced User
Disabling of FW updates is only supported if v4.6.9.11 and beyond.
Orbi 7 and 8 systems work on this version of FW.
- MichaelCLDec 22, 2022Aspirant
I'm having the same issue...
The RBR750 is dropping the internet connection on wired and wireless every few minutes. I updated bot the RBR and RBS750 to the latest firmware. It seems to be less frequent, but it's dropping every 10-20 min now. I know it's the Orbi as I have a stable connection to the built in wifi of my cable modem.- MichaelCLDec 22, 2022Aspirant
I was just on with support and they told me to change the DNS to 8.8.8.8 and 8.8.4.4 and wait for 24 hours to see if it happens again.
