TimCakir
Nov 19, 2022Star
Downgrade and then disable auto update rbr750
Hey guys, abour a year ago I was lucky to find an amazing post on how to downgrade to a stable firmware and disable auto update. It worked for around a year until I moved and made the mistake to fa...
Nov 25, 2022Guru - Experienced User
Disabling of FW updates is only supported if v4.6.9.11 and beyond.
Orbi 7 and 8 systems work on this version of FW.
MichaelCL
Dec 22, 2022Aspirant
I'm having the same issue...
The RBR750 is dropping the internet connection on wired and wireless every few minutes. I updated bot the RBR and RBS750 to the latest firmware. It seems to be less frequent, but it's dropping every 10-20 min now. I know it's the Orbi as I have a stable connection to the built in wifi of my cable modem.
- MichaelCLDec 22, 2022Aspirant
I was just on with support and they told me to change the DNS to 8.8.8.8 and 8.8.4.4 and wait for 24 hours to see if it happens again.
