cv123
Mar 23, 2022Guide
Downgrade RBR853 from 4.6.7.13 to 4.6.7.5
I did the firmware update and it's causing problems with my backhaul. The setup is router to satellite #1, Satellitre #1 with wired backhaul to Sat#2. Worked prior to update but now Sat#2 continually...
Mar 23, 2022Guru - Experienced User
What is the CAT# cable between RBS1 and RBS2?
Did you first wirelessly sync the RBS to the RBR, then once they are fully synced, try to connect RBS2 to RBS1 with the ethernet cable?
Is the RBS directly connected to the other RBS in back or is there a LAN switch or wall jack in between?
Has a full factory reset been performed since last update?
