One-Eye
Nov 03, 2020Aspirant
Download Drops to Nothing Occasionally with RBK852
I own a RBK852, which is the mesh router and a single satellite. The router sits alongside my modem in my office on the 2nd floor, which is right next to the stairs leading down to the 1st floor. The...
One-Eye
Nov 11, 2020Aspirant
The same thing happened again yesterday. My wife moved from her desk on the 3rd floor to just somewhere else in her office and her speed went <1Mbps. I was busy with work so forgot to check the wifi in general but this is becoming really annoying. All of the solutions or tips so far should have nothing to do with the cause of this issue. It seems to be tied directly to my wife's laptop. Almost like it does a denial of serive against Orbi and just kills the wifi.
Nov 11, 2020Guru - Experienced User
Did she turn OFF the wifi radio then back ON again after she had moved locations?
- One-EyeNov 11, 2020Aspirant
My wife simply moved 5-10 feet away from her desk that she had been teaching at all day. That's when her speed dropped under 1Mbps and verified it using a speed test. She then came to the 1st floor where her speed continued to be abysmal. I then turned off and turned back on her wifi. I also did a `ipconfig /release` and `ipconfig /renew`. Both things did not release the issue. I then rebooted Orbi and her speed when to >300Mbps.
- FURRYe38Nov 11, 2020Guru - Experienced User
What is the mfr and model of the LT and the mfr and model# of the wifi adapter with in the LT?
