Elsydeon
Feb 18, 2023Aspirant
Download slower than upload Orbi RBKE963
I am working with a friend who is having slower download than upload when using the Orbi, but not when connected to his Verizon CR1000A. Please help!!
CrimpOn
Feb 18, 2023Guru - Experienced User
"Slower" as in:
- A few megabits difference, or
- 100's of megabits difference?
Is the Orbi in router or Access Point (AP) mode?
Elsydeon
It is 1000ish down/200ish up. I had my friend confirm and he has 1Gb both up and down.
It is setup as a router.
- CrimpOnFeb 18, 2023Guru - Experienced User
If it really is 1000 down and 200 up, I would not be concerned (who has that much to upload?)
Doesn't AT&T have a speed test on their phone 'app' that reports up/down speed to their unit?
- Mikey94025Feb 19, 2023Hero
Elsydeon wrote:It is 1000ish down/200ish up. I had my friend confirm and he has 1Gb both up and down.
Is the CR1000A in bridge mode? If not, while using the Orbi as a router then you have 2 routers operating and Double NAT. Suggest trying the Orbi in AP mode or else put the CR1000A in bridge mode.
I also agree with the other post - These speeds are already far more that anyone needs. 🙂
- ElsydeonFeb 19, 2023Aspirant
Thank you for your assistance.
Is it normal for an Orbi connected to a Verizon modem to get 850 down/150 up on a 1Gb connection?
- FURRYe38Feb 19, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NAThttps://www.verizon.com/support/verizon-router-cr1000a/
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeI would try option #2 first. Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
IF your getting hear 900Mpbs and near 200Mpbs thru the Orbi system, then it would be working as expected.
