Bobkc
Aug 18, 2021Star
Drop in Download Speed - RBR750 with Satellite
I have been using the using the Orbi RBR750 for 8 months now and 30 days ago the download speed dropped from 940mbs to 610mbs. Have noticed the satellite has been indicating that it is receiving per...
Bobkc
Aug 19, 2021Star
I too contacted Xfinity and they told me all was good on their end which when I am ethernet connected to the modem, I can pull the 940mbs. Wireless it drops to 640mbs. I concur with your comments about disappointment and have passed the 90 day free support. Can't rationalize why I should pay for support on a Orbi issue that they are aware of. Would think this would at the top of the priority list. Doesn't make a lot of sense.
Aug 19, 2021Guru - Experienced User
What devices are you using to speed test with?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor enabled?
What CTS values are currently set? Under Advanced Tab/Advanced Settings/Wireless Settings
Try setting 2347 on CTS
