cohenfive
Apr 02, 2025Star
Dropouts with Orbi 960 router/satellites...
I just upgraded my old Orbi rbr/s 50 system to the 960 router with 2 satellites. I was expecting faster speeds and better range vs the old mesh. However, so far while speeds look good, I have had ran...
cohenfive
Apr 02, 2025Star
I chatted with Netgear support around configuring this. They suggested running a line from Xfinity Cable Modem into Orbi 960 router, running a line from the Orbi Router to the switch, and then plugging all our wired connections into the switch. I will likely try this configuration in the next day or so, hopefully that improves things. The Linksys ea9500 should be able to handle gigabit speeds, but maybe it is showing its age with the new, faster wifi mesh.
Right now the satellites are connected wirelessly to the router. That being said, I was considering getting a third satellite and connecting that via one of the wired ports in our house. I would locate that satellite where we are having range issues currently.
Our house is a 4000 sq ft ranch. Difficult configuration, but we have not had any issues with dropouts until I installed the new 960 mesh. One satellite is about 30 feet away, the other one is about another 30 feet away. Dumb question but do the satellites only connect to the router, or can they connect via the next closest satellite? One of our issues is that the cable modem is at one end of the house, so we struggle with connectivity at the other end. We still are, even with the 960 mesh. That's why I was thinking of getting a third satellite and connecting that via one of our ethernet ports at the other end of the house.
Apr 02, 2025Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There a router at this point?
Yes RBS can be daisy chained, wireless or wired to each other.
For that size of home, the RBR and just one RBS should be enough, if running two RBS, I would set the power level to 50% or maybe even 25%. I have a 5k sq ft home multi level and have two RBS, generally set 25% here. Great coverage.
Maybe draw up a floor diagram on mark where the modem, RBR and RBS are placed on it and let us see this.
- cohenfiveApr 10, 2025Star
What does the power setting do in terms of how the mesh operates? I haven't changed any settings, installed the 960's fresh with factory settings.
I'll get the modem information, it is standard, recent Xfinity cable modem.
- CrimpOnApr 10, 2025Guru - Experienced User
The Transmit Power setting affects the strength of the user facing WiFi signals. If two WiFi access points appear to have similar signal strength, some WiFi devices may "ping pong" between them. When Transmit Power is reduced, every WiFi access point's signal strength will decrease. Thus, the total area of strong coverage will be reduced.
Transmit Power has no effect on the backhaul communication between Orbi units.
- cohenfiveApr 10, 2025StarDumb question, what is the factory power setting for the 960 satellites? Am I supposed to increase power settings, sounds like that would increase my range...
- FURRYe38Apr 10, 2025Guru - Experienced User
Helps in reducing some coverage and wifi signal over lap and foot print that if a smaller home is the size, can reduce the foot print and wifi signal overlap between the units to help with overall operation between the units. Also can help with getting the RBS to connect properly to there perspective connection point, RBR or an RBS when daisy chained.
