jsinning
Jul 25, 2023Aspirant
Dropping Connection randomly but multiple times a day
I am running the ORBI AX6000 system with 3 satellites in my house. We are routinely dropping connections throughout the house. The satellites are not great distances from the main unit and each tim...
jsinning
Jul 27, 2023Aspirant
What Firmware version is currently loaded? V4.6.14.3_2.3.12
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Cisco DPC3008
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Done. This does not appear in any way to be internet related. Speeds are amazing and every time the WIFI drops out I can still connect to ORBI remotely through the APP.
What is the size of your home? Sq Ft? 2500 between the main floor and basement
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS.
No issue there they are more than 30 feet.
Does this happen with the RBS turned OFF? Yes, it appears to be from the main unit as when it happens the satellites also lose connection and begin to flash white.
Does this happen with both wireless and wired devices? The only thing wired direct in the house to the main unit is the cable modem.
What channel configurations are currently set on the router? 2.4 Ghz is auto and 5 GHz is 48
This happened yesterday morning and again 5 times last night in very quick succession.
Jul 27, 2023Guru - Experienced User
Where is the RBR located in the home? Main level or basement?
Does the front LED on the RBR flash any colors?
For that size of home, the RBR and just 1 RBS is needed. You may have too much wifi signal and overlap.
Too Much Wifi: https://youtu.be/UR0viMLISz4
Please turn OFF all but 1 RBS.
