LinM
Jan 19, 2020Follower
Dropping Wifi on Orbi RBK850
I am running an Orbi AX RBK850 with two hard wired satelites. The Orbi router is directly attached to the AT&T Arris BGW210. I have worked with the AT&T techs to get the IP Passthrough set up and a...
ekhalil
Jan 19, 2020Master
The Ariss BGW210 is also a router. If Orbi is set in Router mode then you should set the Ariss router in bridge mode. Please see the following article on how to bridge this Ariss router: https://www.reddit.com/r/Ubiquiti/comments/b1x5l6/how_to_properly_configure_the_arris_bgw210_for/
On the other hand I still see that there is still an issue with wired backhaul in the Orbi AX firmware. In my case every 3-4 days all wifi will start dropping and I need to reboot Orbi to fix that issue. Orbi AX still works much better and is more stable with wireless backhaul than wired.
