MiddKid
Nov 01, 2020Guide
Dual Routers: Comcast and Orbi
From years of setting up routers, I know I shouldn't have two routers on the same network. One should do the routing, the other should be in Bridge/AP Mode. But I come here with a question. I j...
Nov 01, 2020Guru - Experienced User
This will work ok. One item to enable is DMZ or IP pass thru on the ISP modem/router for the RBR. This will help with doube NAT issues.
