MiddKid
Nov 01, 2020Guide
Dual Routers: Comcast and Orbi
From years of setting up routers, I know I shouldn't have two routers on the same network. One should do the routing, the other should be in Bridge/AP Mode. But I come here with a question. I j...
Mikey94025
Nov 02, 2020Hero
MiddKid wrote:So my question is...in the ensuing months with both the Comcast and Orbi boxes performing routing duties should I expect there to be issues? Or is it going to work just fine (similar to how it's working fine right now at the end of our set-up call)?
It will probably work fine. The only functional issues with Double NAT are usually things like games or special port forward needs, which your dad is probably not doing. If he hasn't yet encountered something broken then it will continue working.
I'm running with Double NAT now myself, and have been for months. My Comcast router is connected to my Orbi RBR850 as well as my Orbi RBR50 (which I run for guest network and compatibility with some devices that don't work with the Orbi AX like my Nest thermostat and August lock).
