75Panther
Oct 04, 2022Aspirant
EasyMesh Orbi RBK752 Support
Hi, I have an Orbi RBK752 mesh system connected to a Motorola MB8600 running 300Mbps using Comcast as my ISP. I will be converting to Frontier fiber which will be running 1G internet speed. As part...
- Oct 04, 2022
75Panther wrote:
Thanks for the info. Is there an option you would recommend? Option #3 for easiest configuration.
So, if I implemented option #3 the Eero modem/router would be the Router and the Orbi router would be reconfigured from routing to acting as an AP only? Yes.
Would the Eero node and the Orbi satellite still work in this environment? Yes.
Oct 04, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
- 75PantherOct 04, 2022Aspirant
Thanks for the info. Is there an option you would recommend? So, if I implemented option #3 the Eero modem/router would be the Router and the Orbi router would be reconfigured from routing to acting as an AP only? Would the Eero node and the Orbi satellite still work in this environment? So for my ignorance!
- FURRYe38Oct 04, 2022Guru - Experienced User
Appreciate your help. Will give it a go
