75Panther's avatar
75Panther
EasyMesh Orbi RBK752 Support
Hi, I have an Orbi RBK752 mesh system connected to a Motorola MB8600 running 300Mbps using Comcast as my ISP. I will be converting to Frontier fiber which will be running 1G internet speed.  As part...
  • FURRYe38's avatar
    75Panther wrote:
    Thanks for the info.  Is there an option you would recommend? Option #3 for easiest configuration.
    So, if I implemented option #3 the Eero modem/router would be the Router and the Orbi router would be reconfigured from routing to acting as an AP only? Yes.
    Would the Eero node and the Orbi satellite still work in this environment?  Yes.
